I have an AC200L in my motorhome that I am charging with the charger1. The charger 1 uses solar input so I’m looking for a way to plug in the solar I have on the roof. I have a D050s that I was going to use with a B230 but they have been discontinued. I don’t need the B300 but they are out of stock anyway. Any suggestions on how to connect my panels while using the charger1?
Hi I currently use a D050S feeding into the AC adapter input port so that I can charge off solar and the D050S at the same time, so similar to what you want to do apart from I feed solar into PV port and Vehicle power into AC adapter.
Hope this helps
Dennis
