I notice that the firmware for the 200 v2 enabled a sleep mode that allows the unit to always be powered on and not auto shutting off after 4 hours. This is different from the eco mode. Can you Bluetti guys enable this function on the 100 v2? I would like the unit always powered on, even without the ac or dc being used.
If you turn off the ECO mode on the Elite 100 V2, the device will not automatically shut down. Please try this setting, and if you have any other questions, feel free to let us know!
Thank you!
Come on @BLUETTI please get a grip, this is not what the poster is requesting and not the same solution that has been provided for the 200 v2.
As I expected, the power auto shutoff after 4 hours.
Here is the reply to a 200 v2 post about the same issue. I had ECO mode turned off for the AC already and am turning off DC now. I suspect the unit will shutdown in four hours automatically. We’ll see what happens. See the 200 v2 reply below:
Hi @marsman, It seems that you need the Elite 200 V2 to remain powered on instead of completely shutting down when the AC/DC output is not activated, is that correct?
Based on your requirement, we have a new firmware that enables the Sleep Mode.
Please upgrade to the latest firmware and app, then you can activate this function via the app.
After enabling this feature, the Elite 200 V2 will enter Sleep Mode after being unused. It can be remotely awakened and powered on through the APP. If the SOC is lower than the reserved SOC (State of Charge) value set in the Sleep Mode, it will shut down completely and can only be powered on by the power button on the device.
There is no “Sleep Mode” selection on my Advanced Setting section of my app.
Is there an upgrade for the 100v2 firmware then??
