With AC and DC turned off and nothing plugged in, my AC200MAX has dropped from 100% to 35% some time between 6pm and 9pm. I typically charge with solar. This is a recent issue. Attached is the Product Information and two screen captures.
@bluetti_chrislwrighticloudcom
Engineer has pushed a new firmware version to your machine, please update it in time.
(Login to your account and connect your device with Bluetooth to update.)
After the update, perform two full charge/discharge cycles to see if the problem has improved.
The firmware update instantly fixed the issue without needing to charge and discharge. Thanks!
Hi Bluetti.
I have exactly the same issue.
My AC200 MAX will drop from 100% to 35% SOC, even if completely powered off and disconncted from Solar and any loads.
S/N: AC200M2217000740740
ARM v4008.03
DSP v4005.07
BMS v1017.02
Can you push the latest firmware to me?
Thanks.
@Maxik Received. You are expected to receive a push notification of the firmware update within 5 hours.
Please keep an eye on the app and keep it updated at that time, thank you!
