LOL, you mean this picture of what is included is inaccurate? I’m shocked! ![]()
Ok, so connector questions aside, some of the detail of your panels are not clear, but it seems you have a Rich 100 watt, and is the other one a 150 watt panel? And how are you connecting these 2 panels to your AC200M, series or parallel?
Also, have you tried connecting just one of them at a time? Since the minimum solar input is 10 volts it should work to just connect a single panel.
Yes…… I tried every and all combinations possible!!
I have a BS in mechanical engineering and certified HVACR tech
With all my testing, one thing stands out…… the MPPT controller is reducing the input drastically
To achieve 900 watt input I will have to have 1400 watts of solar panels
From the photo you can see that the battery is at 84%, have you tried with the battery at 50%?
