The B300K is now officially launched on BLUETTI US&CA! 🚀
So it’s a stripped down version of the B300s, with only 1 USB outlet, minus about 300 Watt-hours, and minus the extra solar input and inverter
Currently, it’s $456 cheaper than the B300s but I would still have to buy a converter cable for each battery, (another $100?)
I have an AC500 with 6 B300s, so if I wanted to add a 2nd AC500 setup it would be a lot cheaper overall.
This guy has some discount codes.
Use the extra code OzarkB300K for 13% off for the B300K battery before 9/27.
Use the extra code OzarkB300K2 for 8% off for the AC500+2*B300K before 9/27.
I saw a photo on the site with 3 B300Ks stacked. I thought you couldn’t stack more than 2 batteries.
Can we safely stack 2 B300 + 1 B300K and the AC 300 on top?
I´ve seen guys that stack all 4 batterys (B300) as tower. I stack two B300 and one B300K on top with the AC300 and it works solid. You just should place it on a suitable stable ground.
