My new AC180 keeps turning completely off even though ECO mode is disabled for AC
Hi @Mithiin and @Svitoch, Now I have applied to upgrade your firmware.
Our IT department will push the latest version of firmware to your unit in 24 hours.
@BLUETTI_CARE
I have the same problem, please help, I cannot use it as UPS as it is.
Hi @Hubris, Now I have applied to upgrade your DSP.
Дякую, після оновлення працює як ups, поки без нарікань, спостерігаю далі.
Hi @k123z, Thank you for letting us know.
We hope everything goes well.
My brand new AC180 shuts off completely when AC charge is 100% after 30 min. How do I handle this? Cannot use as a USP.
…no updates available.
Does this happen when there is no load, or a very small load, connected? If so they you may need to turn off the ECO mode for the AC output.
Same problem, AC180 randomly shuts down, doesnt matter if battery is full or not or if its plugged in or not.
I have corroded electronics inside my ac180. Can I have it repaired under warranty?
AC180. My AC180 turns itself off even when not in ECO mode, making it a poor choice as a UPS. I understand from this thread that there is a firmware update available to be pushed to our machine. Please do so for me. Thank you.
AC1802438002032967
ARM v2107.03
DSP v2102.04
BMS v1052.03
Hi @sgiersch, Now I have applied to upgrade your firmware. Our IT department will push the latest version of firmware to your unit next Monday.
Please upgrade the firmware then. Please do not load any device when upgrading it.
My AC180 also suffer this issue, ECO mode all disabled.
AC1802338000851412
ARM v2074.07
DSP v2078.06
BMS v1033.12
Hello i have the same problem… turns off after pulling the unit drom the grid
Iot: v9046.04
ARM:v2074.08
DSP:v2078.06
BMS:v1033.12
Sn:AC18O2509006122111
Hi @Leomel91, thank you for getting in touch with us.
Now I have applied to upgrade your system to our IT department. They will push the latest version of firmware to your unit in 24 hours.
@BLUETTI_CARE
Hello i have the same problem (
Iot: v9046.04
ARM:v2124.04
DSP:v2126.02
BMS:v1052.02
Sn:AC18O2422001481424
Hi @Hopr, thank you for getting in touch with us.
Hello @BLUETTI_CARE
It looks like I got the same issue with unexpected shutdown while in UPS mode.
All ECOs are disabled, output is ~500W, battery is at 100%, connected to grid (not stable).
BMS: v1052.02
IOT: v9046.04
ARM: v2124.04
DSP: v2126.02
SN: AC1802418000220493
Hi @Freezy, thank you for contacting us.
