How do I figure out how many solar panels I can use for my AC300
Well ya’ll got me nervous. I was excited because I didn’t like the idea of connecting the 460w panel to ONE battery…and not the other. I was concerned it would result in one battery aging differently than the other. So, sharing the over wattage between the two 200w inputs seems logical.
So, what might happen if it goes wrong? What does “mess up both” look like?
Is there an economical solution that could take the single PV outputs, and manage sending out the right amount of power to the B300 batteries? In other words, something other than a Y on the wires hoping the right amount goes to the right place?
Thanks!
There is a simple way to check that it is working properly when your additional panel is under the sun, and the b300 are connected in parallel with the y cables: disconnect the b300 from your ac300 (to be sure that they are not charged by your ac300) and observe the green LEDs on your 2 b300. if they both run (chasing) at the same rate, regularly, it is working!
I’m thinking about it to see if there is another solution! (I don’t see any at this stage)
I hate to do this, but I have made a few post about my solar panesl not charging my Ac300, and B300 batteries. I have them run ing in series and test everything but sitbis not working. Again sorry to make this post on your question. Thanks
