Grounding Bolt
I just received my AC180 and noticed it has a grounding bolt socket on the side. What do I need to do with this? In what instances would I need this to be grounded and ground it to what?
AC180 (all BLUETTI power stations) are off-grid machines with a floating ground. In general, there is no need to use a grounding screw. However, in some cases where certain equipment requires grounding, a grounding screw is needed to connect the machine to the ground wire.
