@bumpfmurzel The background checks that you have completed the firmware upgrade. Please try to charge EB3A with EB150 to test.
Is the confusion of labels part of the distraction or manipulation?
The error pattern has not changed.
@bumpfmurzel If the software update can’t solve the problem, I think it has nothing to do with firmware.
Guten Morgen,
ich habe seit heute folgendes Problem:
Wenn ich über das Netzteil auflade, dann lädt die BLUETTI einige Sekunden, schaltet die Ladung wieder aus, dann wieder an usw.
Eine Ladung ist somit nicht mehr über des 230 V Netz möglich. Gibt es da einen Tip?
Danke Fri
Please check as below:
- Check whether the screen reports an error, such as Temp. If it reports temp, please stop charging and unplug the load, place the EB3A in a cool place, and recharge after 2 hours. If it is winter, put it in a warm place for 2 hours.
- Check if the Circuit Protector on the right side of the AC input port pops up, press it and try AC charging again
- In the power-on state, press and hold the AC ON and LED ON buttons at the same time to check if there is a fault code.
- Upgrade the APP to the latest version
- Try another AC charging cable to test
zurücksenden solange es noch geht
