Ac300 + rigid solar panels and limitations
A lower solar radiance will reduce both voltage and current outputs. If you are wary of the maximun Voc reaching or passing 150 VDC, do a test of the panels in series and measure its Voc. I suggest using a multimeter that can store a peak (Max) reading so you don’t need to be waiting all day and watching the display.
