AC200MAX Lock Icon
I don’t think you will be able to get a work around with out having to go back to the supplier/vendor of the unit. it will need someone fairly technical to understand what you require.
Yeah, you have a point. I will see if I can get them to give the vendor’s contact details. Thank you for the help, much appreciated.
It seems that you need to contact your seller for an unlock code. If they can’t or don’t want to supply it, arrange a return/refund from your seller for non-conformity.
Unless you rented the unit or have a pre-paid system. Then you may need to make a payment to use solar power. (Pay-as-you-go)
