Меня тоже интересует этот вопрос как snmya.
Hi @snmya, Thank you for your attention to Bluetti.
The new firmware will automatically enable this feature.
Once the feature is activated, it will remember the AC/DC switch settings when the SOC drops to 0%.
When power is restored and the SOC reaches 5%, the settings will automatically revert to the previously remembered switch state.
Please note that when the AC power source is connected, the output settings will be restored immediately once the SOC reaches 5%. Without AC input, the settings will enable only restoration after the SOC reaches 5% and remains stable for 30 minutes.
Currently, this feature is tied to the new firmware, meaning the memory function can only be enabled and cannot be turned off via the app. At this time, we do not have a plan for app integration and cannot provide a definitive timeline.
Привет
Я хочу получить новую прошивку для своей AC200pl
Но у меня ещё возникла проблема с работой вентилятора
В режиме UPS cactom, когда станция работает от АКБ,но включен в сеть GRID, вентилятор работает всё время при нагрузке 120-150Вт
Если в этом же режиме,но только от сети(без АКБ) вообще не работает вентилятор.
А если отключить сеть то работает периодически.
Как и в стандартном режиме ups
Помогите решить проблему
Thank you for the information. I see that you posted below that at the moment it is not proposed to enable this feature to be turned on and off via the app. I would really prefer to be able to do that, especially for the AC180P which is used for other things than a fridge. Is it that it would be too difficult to make this feature turn on / off in the app?
Hi @Tezzabee, Thank you for sharing your feedback, which reflects the thoughts of many other users. We have passed it along to the R&D department.
Turning this feature on and off in the AC180P app doesn’t difficult, but for new customers, it does require some learning and adaptation.
Hi @Pletenets, We believe this is a normal phenomenon.
The fan on the AC200PL operates under the following conditions:
- Charging/Discharging Power: When the charging or discharging power reaches a certain threshold, the fan will start.
- Internal Temperature: When the internal temperature of the AC200PL reaches a certain level, the fan will also start. As the temperature decreases, the fan will stop.
Additionally, each time the unit is powered on, the fan will briefly run as part of the self-test.
When only the grid bypass load is used, the power station itself doesn’t output, so the internal temperature doesn’t get too high, and therefore, the fan doesn’t automatically turn on. This does not affect usage and will not cause the machine to overheat.
Добрий день
Дело в том что я специально долгое время наблюдал за работой вентилятора.
Когда розряд идёт только от АКБ, всё верно,вентилятор периодически включается и отключается,это нормально.
Это и в режиме ups cactom и ups standard,это всё работает хорошо,по мере нагрева вентилятор включается и отключается.
Но когда в режиме ups cactom идёт розряд от батареи,но включаю просто станцию в сеть,вентилятор работает без перерыва, постоянно,он не выключается вообще никогда,при том станция холодная и это не зависит от нагрузки.
При одинаковой нагрузке, Я отключаю станцию от сети и вентилятор отключается,включаю в сеть и он постоянно работает,розряд так же идёт от станции,заряда нет.
Я просил сдесь snmya,у него тоже станция ac200pl, он включал такой режим и у него вентилятор не работал.
Но у него насколько я понял какая то другая прошивка по работе вентилятора.
Хотя всё номера прошивок у нас одинаковые.
Может можно и мне такую прошивку?
Прошу помочь,так как я постоянно использую режим ups cactom и постоянная работа вентилятора для меня негативная,мне приходится отключать станцию от сети и следить когда батарея розрядится до 10%,потом включать ее в сеть.
Возможно в прошивке в этом режиме есть какая то проблема,недоработка?
Hi @BLUETTI_CARE ,
Thank you for your reply.
I think there was a misunderstanding. I meant would it be too difficult for Bluetti to make it possible for this feature to be turned on and off via the app, rather than it always being on once installed?
Thanks.
Hi @Tezzabee, Thank you for your attention to Bluetti.
We believe that enabling and disabling this feature on the AC70 through an app would necessitate the creation of a separate, new version of the app. We consider this process to be quite cumbersome and time-consuming.
If you don’t mind, we could push the update to you for testing. If you find it unsatisfactory after testing, you also have the option to revert to the original firmware.
Hi @Pletenets, I am sorry for the inconvenience.
Currently, we don’t have firmware that allows control over the fan.
However, if you don’t mind, we can try upgrading your firmware to the latest version. This might help, but we cannot guarantee it. Please provide your SN code and the current firmware version.
If this doesn’t resolve the issue, we may need to contact customer support to arrange a replacement.
Доброго дня
AC200PL2429003755199
IoT2428003926096
Прошу помогите,так как замену я не смогу сделать,я in Ukraine,и это просто невозможно,нет смысла
Или in Ukraine уже есть сервис?
Hello! Is this the same for AC200PL/AC180P? Or is it easier to update app with option for these?
Hi @BLUETTI_CARE ,
Thank you for the explanation.
Yes, please send the update for me to try out.
Thank you
Hi @Pletenets, Now I have applied to upgrade your firmware. Our IT department will push the latest version of firmware to your unit in 12 hours.
Regarding the repair issue, we understand that the repair process in Ukraine is very inconvenient. Since the operation of the fan does not impact the usage, we will do our best to help optimize the system according to your needs. However, at this point, there is no need for a repair.
Hi @snmya, The new firmware for the AC180P has not yet been completed and is expected to be released in March. Please wait till next month.
It would certainly be more convenient if an app could be developed to enable the shutdown function for the AC180P. However, we do not have specific information on this at the moment.
Hi @Tezzabee, Now I have applied to upgrade your firmware. Our IT department will push the latest version of firmware to your unit in 24 hours.
Спасибо.
А в этой новой для меня прошивке уже будет добавлена опция включения AC после полной разрядки?
Или это уже потом ещё нужно будет просить там это включить?
Hi @Pletenets, After upgrading to the new firmware, this feature will automatically activate and does not require manual enabling.
Once upgrade the firmware, it will remember the AC/DC switch settings when the SOC drops to 0%.
Да я это знаю, меня устраивает это.
Я просто хотел уточнить в этой последней прошивке уже будет и автоматическое подключение AC и может быть решена проблема с работой вентилятора,как в моем случае?
Хочу еще поделится своими наблюдениями по поводу постоянной работы вентилятора,которую описывал више.
Сегодня провел эксперимент,в приложении переключил режим зарядки из тихого в стандарт и вентилятор стал работать с перерывами,то включается,то выключается.
Включаю режим зарядки на тихий,и он работает постоянно.
Тоже самое и когда станция заряжается в режиме тихий,вентилятор работает постоянно.
Похоже проблема где то в прошивке,связанная с режимом тихий.
Возможно это поможет техническому отделу разобраться и сделать работу вентилятора адекватной.
