I didn’t spot the oven before as I have never heard of this type. So it uses about 72 watts? It is quite impressive what it can cook.
@Tezzabee As mentioned, it will heat any precooked frozen food, such as meat pies, sausage rolls, pasties, pizza as well as it will cook a small roast beef, potatoes, carrots in around 3 hours.
Its primary use is heating rather than cooking.
https://travelbuddy.net.au/products/ This is its web page, as mentioned if it is geoblocked to your country, you will need a VPN and open an Australian server to view it. I have the small T/Buddy.
A frozen pie takes around 90min, thawed 45min. I usually remove a frozen pie from the freezer early morning and put it in the fridge section. Without preheating I place it in the T/B 1 hour before lunch and its ready at the 60 min mark. It has 2 wire shelfs that will hold 4 pies, which are removable. Its biggest limitation is size re cooking.
It will also reheat any leftovers that will fit, such as, pasta, rice, stews etc. The bigger 12V oven uses around 10A. The smaller one I have comes with a cig plug which I cut off and replace with Anderson. They also do a 24VDC version. The bigger units are recommended to be hardwired, but Anderson from an Auxiliary battery is ok. There are other brands in AU. ![]()
