I will do that when I finish calibrating my last new battery in a few hours. And yes, I’m only connecting a single battery at a time for the calibration process. What is the latest BMS version for the B300S?
For @BLUETTI_CARE, Success. After completing the calibration for the 2nd new B300S, I reconnected all four batteries to the AC500 and there was no change to the Home SOC display. It read 39% or roughly half what it was supposed to (the two older B300S were at 79&80% and the two new ones were both at 100%). Then I updated the BMS on the two older units from 1022.08 to 1022.09 and as soon as I reconnected everything, the Home SOC immediately changed to 90%, which is what it should have been. I rechecked all four batteries using the app and it reports that all the BMSs are up to date, even though the older two are at 1022.09 while the two new ones are at 1022.13. Is this correct and there’s no reason to try to find any updates for the .09 units to get them to .13?
While doing all this, I noticed that the app also reports that my AC500 has available updates. Specifically, ARM from 4044.04 to 4044.07, DSP from 4045.04 to 4045.30, and IoT from 9041.02 to 9041.10. The latter 9041 one says it adds the Bluetooth encryption feature, but I have no idea what the ARM and DSP add or fix. Should I go ahead and upate all of those (IoT, ARM & DSP)? Thanks for your help.
Hi @TMan, Regarding this issue, we believe that pushing the new BMS firmware to the two older batteries is a good solution. Please provide us with the SN code of your AC500 so that we can push the new BMS firmware.
As for the ARM v4044.07, it resolves the issue of being unable to configure settings via the touchscreen.
The DSP v4050.30 fixes the problem where solar charging power is limited under high-power AC loads.
The new IOT firmware optimizes Wi-Fi connectivity and app data statistics.
If you are not experiencing these issues, there is no need to upgrade these firmware versions.
Hallo BLUETTI_CARE,
I’m also need the DSP v.4050.30.
AC5002241000324376
IoT2236001010612
Thanks Joachim
Hi @BLUETTI_CARE. I actually have two AC500 units, one with the four batteries (the two new ones plus two older ones), and the other with two of the older batteries. Since I may need to move batteries from one to the other in the future, please push the new BMS firmware to both of my AC500s so I can easily upgrade all four of my older batteries.
(1) AC500 - 2239000831419
(2) AC500 - 2252000462587
I appreciate your help.
Hi @Akel, Can you tell us the current DSP version of your AC500?
Then we will apply for pushing the new DSP for you.
Hi @TMan, Thank you for getting back to us so quickly.
We have now requested to push the latest BMS to your two AC500 units. The push will be completed within 24 hours. You can upgrade tomorrow or whenever it is convenient for you.
Please ensure that only one B300S battery is connected during each upgrade. Please do not load any device when upgrading it.
After that, please try to do a complete cycle of discharge and charge to correct the SOC. The problem will be resolved.
- Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
Thanks @BLUETTI_CARE. Will do. With 4 batteries to update & recal it’ll take me several days to complete, but I’ll post how it went after finishing the process.
"Hallo BLUETTI_CARE,
AC5002241000324376
IoT2236001010612
Thanks Joachim"
My actual DSP-Version is 4047.30.
Hi @TMan, Yes, We have pushed the latest BMS v1022.14 to your two AC500 units. Please connect only one battery at a time for the upgrade.
However, during the recalibration process, it is not necessary to calibrate each battery individually.
We look forward to your feedback on the new firmware.
Hello @BLUETTI_CARE, I finally got all 6 batteries (4 older ones + 2 new ones) updated to the v1022.14 BMS firmware and calibrated. They’re currently all at 100% and the SOC shown on the Home screens are also at 100% on both AC500s. One AC500 has two batteries and the other has four. I’m going to discharge both systems for a few hours using my DIY AC load set at 1.0Kw followed by a charge to see how synchronized the individual batteries remain during that process. Hopefully they’ll stay synchronized. Thanks for your help.
Hi @TMan, Thank you for sharing, everything seems to be normal at the moment.
We hope everything goes smoothly.
Burn them all down to zero and actually shut off, then recharge…sometimes it needs to recalibrate…but machine absolutely needs to literally shut down/off.
Good time of the day @BLUETTI_CARE
One of my batteries BMS 1012.xx version and no possibility to update (telling me that you have the latest version). Can you help me and push the update for me, please?
My AC300 s/n AC3002225000758952
My problem is that 2x B300 battery modules are different SOC (98% and 56%) but I don’t want to keep my battery more than 80% (for it’s health)
And very important question for me @BLUETTI_CARE : now I don’t have the Blackouts and my AC300 is always on (just in case of emergency- because of war in my country). Do I need to disconnect one B300 to save its health (charge it for ~ 75% and disconnect) and leave the other B300 in production? After 1 month I will do the rotation of my active battery B300 will be disconnected and offline one will be connected.
What will be the best? To leave it connected and working or disconnected and do the rotation every month (2,3,4 ?)?
Hi @Arvian, We are more than happy to assist you. We do not have a B300 battery with a BMS version starting with 1012, but we do have versions starting with 1021. Could you please double-check and provide the correct BMS version number? Then, we can check if a new firmware update is available for you.
We do not believe that keeping the B300 at 80% charge would be healthier for the battery. From the very beginning of designing our products, we aimed to provide customers with a convenient experience, allowing 24/7 continuous charging and discharging. While we completely understand your intention to extend battery life, we do not think this is necessary, nor do we have firmware currently specifically designed to meet this requirement.
We recommend that you connect the entire system and use it as normal. If possible, performing a recalibration every three months would be beneficial. To do this, fully discharge the entire system, then disconnect and separately charge each B300 to 100% before reconnecting the full setup. This helps manually maintain SOC balance.
Hi @Arvian, Thank you for letting us know.
We have applied to upgrade your BMS. Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Please only connect one B300 with the AC300 at a time, and do not load any device when upgrading it.
- Please charge it again. Please do not load any device when charging it, and do not interrupt it while in charging.
Thanks @BLUETTI_CARE for the fast and helpful info - and for the BMS update!!! I was really worried about the differences of my BMS versions.
Hi @Arvian, You are welcome!
Please let us know if it works well after upgrading the BMS and recalibrating.
We hope everything goes smoothly from here!
Hello community
@BLUETTI_CARE thanks a lot, I received an update firmware.
But (oh this “but”
) but I will have different versions even after an update (please see the screenshot). My question is “do I need to update my v1014.16 on v1014.18? Other battery will have v1024.04.”
