Hello sunhouse: Concerning your AC200MAX.
I would be a little hesitant to use those 3 x 410W panels in series because the AC200MAX maximum input using the solar is supposed to be 900W a little over is ok, but I don’t think you should connect more than 2 of them. Your OCV is ok and your IMP is ok, but your solar input may get too high for the AC200MAX.
I currently have 2xPV350’s (OCV/VDC)= 46.5 x 2= 93 and 1xPV200 (OCV/VDC)=26.1 for a total 119.1 well within operating range for the AC200MAX.
The PV350 IMP (AMPS) is set at 9.2 and the PV200 set at 9.7, so the only problem here is the IMP will be lowered to the lowest number, in this case 9.2.
The total amount of watts generated from solar will be up to 900 (a little bit more in excellent conditions) is ok.
B
Canada stands with Ukraine
