Low grid voltage error on AC180P
Hi @Charnoir, Now I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 1 working day.
Please upgrade the firmware next Monday. Please do not load any device when upgrading it.
Could you, please, send me the upgrade to make my station ( grid self-adaption option is enabled ) charge itself when grid voltage is 180-190 v.
AC180P2332001219563
ARM2089.04
DSP2088.04
BMS1039.01
Hi @BLUETTI_CARE. I have 2 AC180P stations. Could you please update both to be able to charge with low voltage?
SN1: AC180P2433001454932
SN2: AC180P2438000401787
Thanks.
2 BLUETTI_CARE
Hello, i have same problem like other guys - my device does not charge when grid voltage drop to 180v and sometimes even lower(error 114). I turn on grid self-adaption option in settings and silent charging mode but it does not help.
Could u provide custom firmware solution for my device?
AC70P2404000260918
ARM v2122.07
DPS v2112.06
Thanks in advance.
Hi @bluetti_sssawa298gmailcom, we’ve noticed that your AC180P is already running the latest firmware version. Unfortunately, we’re unable to push a firmware update at this time.
Low or unstable voltage may be preventing charging. Could you please try enabling Silent Charging Mode? We hope this resolves the issue.
Hi @Veklich74, we would like to help you.
Can you tell us the current firmware version of your 2 AC180P units?
Hi @Slytusk, it’s our pleasure to help you.
Now I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 24 hours.
Thanks a lot, I got update and it really help in our situation.
Hi @BLUETTI_CARE
The same issue.
AC702434002141394
IOT: v9046.04
ARM: v.2151.05
DSP: v.2106.09
Hi @Jeans8787, we would like to confirm whether you have enabled Grid Self-adaption and Silent Charging Mode. Have these functions worked effectively for you?
Hi @Slytusk, that is great, we are glad to hear that!
Thank you for letting us know!
Thank you very much my friend! Everything works after updating.
Hi I have the same problem. I have tried enabling Grid Self-adaption and Silent Charging Mod,e but the chargedoes not start.
AC180P2344000920924
ARM: v2089.04
DSP: v2088.04
BMS: v1039.01
Hi @BLUETTI and @BLUETTI_CARE!
AC180P2434000130402
IOT v.9046.04
ARM v2125.04
DSP v.2126.03
BMS v.1048.05
In Ukraine we have constant voltage problems due to russian bombings. Thanks in advance.
Hello, I have registered your device for a firmware upgrade. Please wait patiently.
Hi @apanchenko, we’ve noticed that your AC180P is already running the latest firmware version. Unfortunately, we’re unable to push a firmware update at this time.
Low or unstable voltage may be preventing charging. Or you can contact the service team for support.
Hello @BLUETTI and @BLUETTI_CARE , I followed the instructions provided in the app: installed the latest firmware version, turned on grid self adaption and set the charging mode to silent. The voltage is around 180V, but unfortunately the charging doesn’t work :(
Do you have any suggestions?
Hey, i live in Ukraine and there is always low voltage (170-190) from a socket after a power shutdown, and i’m getting error E114 so could you please push me a modified firmware so i can charge my power station.
SN: AC180P2438000551133
BMS v1048.05
IoT v9046.04
ARM v2125.04
DSP v2126.03
Hi
I have two AC180p stations. Currently, there are problems with electricity in Ukraine, and the voltage is around 180 V. Both stations are not charging even though the firmware has been updated and grid self-adaptation mode and silent mode are enabled. Please update the firmware on both stations for me.
AC180P2349002264629
ARM v2089.04
DCP V2088.03
BMS 1039.01
AC180P2445000332065
ARM V2125.04
DCP V2126.03
BMS 1048.05
hi there.
had the same issue with AC180P not charging at low voltage throwing E177 despite voltage is something of 90% of 230V
please send me an update if possible
AC180P2433001710648
IOT
v9046.04
ARM
v2125.04
DSP
v2126.03
