I need to lower Max Grid Input Current
I too have a power source that is limited to 800W. Is it possible to reduce max current accordingly i.e 5Amps?
I have the same behavior…
The grid current on the AC300 can no longer be changed. Neither pressing the predefined values nor entering a user-defined value changes the setting. The value that I assigned at the beginning during setup always remains active. So the only solution ist to swap the device?
Daniel
Hi Daniel, I would recommend contacting the Bluetti support, because the values should definitely change. I had to replace my first unit due to this issue.
o.k. - thanks for your advice. The ability to adjust the current is not absolutely essential. I will therefore wait a little longer. Maybe there will be an FW update or something similar.
Bluetti can send you the numeric password to change the AC charge current. My AC300 came with a 15 A default. Now I can charge it at 30 A.
