EB3A Shuts off at 75% and wont turn back on
I have this exact issue, mine is shutting off at 44% consistently. I’d appreciate the firmware update as well.
EB3А2219003203694
ARM v2057.11
DSP v2056.10
Hi @BLUETTI_CARE,
Thank you for the reply and the latest firmware upgrade (it was ARM v2063.03 to v2063.04) Unfortunately it didn’t resolve the problem. Pretty sure the BMS isn’t functioning correctly and showing an inaccurate SOC is an obvious sign even after charge/discharge cycle(s). I don’t wish to bog this thread up any further as it doesn’t “fit” the overall nature of this thread and associated replies from the community so should I contact Bluetti on alterative channels or can we perhaps take this elsewhere? I also have a similar issue with my AC70 which I’d like to discuss. Awaiting your advisement,
Thank you,
Drew
Hi @bary, We are not entirely sure if the new firmware can fully fix this issue, but we will still apply to push the firmware for you.
They will push the latest version of firmware to your unit in 24 hours.
If it doesn’t work, please try recalibrating.
Hi @miodice3, We are not entirely sure if the new firmware can fully fix this issue, but we will still apply to push the firmware for you.
Hi @Drewman, we would like to help you.
If you have any questions about how to reach the appropriate customer service team or concerns about the service process, please click my profile and send us a private message with your order information so that we can arrange priority service for you.
Hi @BLUETTI_CARE, I can’t see how to raise a PM to you.
All I have is Discobot tutorial message/mail.
Would it be possible for you to PM me so I can reply?
Thank you in advance
Drew
Hi @Drewman, Just click on my profile picture and then select “Message”.
We will send you a message shortly, so please keep an eye out for it.
I also am experiencing this issue. No matter how many times I try to calibrate it it still shuts off around 50% and won’t turn on again until its plugged into AC.
EB3A2223012153316
ARM v2057.11
DSP v2056.10
I’m seeing a similar issue when it reaches 77% SOC it shuts off and needs to be plugged in to turn on.
Serial - EB3A2338002112279
Arm 2057.11
FSO 2056.14
Great! Now the VSP revision shows 0. Worst timing to have a useless portable power station. Last time I’ll buy a BLUETTI product that’s for sure.
Hi. I’m having the same issue with my eb3a. Can I get in line for a firmware update too please? Thank you.
EB3A2320002384865
ARM. V2062.03
DSP. V2056.12
Hi @BLUETTI_CARE , the same issue with both my stations (power off at 37% and 40%). Firmware versions:
ARM v2063.03
DSP v2052.11
My Eb3A shuts off when it reaches 76%, I have tried to do the drain down and recharged with little or no change. Someone please send me the firmware
EB3A2231000482600
Arm v2057.11
Dsp v2056.10
Hello, To assist you further, please consider the following points:
  1. Is the machine charging normally or powering any devices? Have you turned on the ECO mode?
  2. If the machine is not charging and AC or DC is off, it will automatically shut down after one minute to save power.
  3. If the machine is in ECO mode without any load or with very low power, it will automatically turn off AC and DC after 1 to 4 hours (the specific time can be set in the app) and then shut down after some time.
  4. If the machine is only charging via PV and AC or DC is off, it will stop charging at night and shut down after one minute, only to reactivate the next morning when PV charging resumes.
  5. Please check the error code screen to see if there are any historical error codes.
My EB3A won’t charge after i ran it down until it shut off.Now it reads 100% and wont charge.I tried using a laptop charger and it went 99% and stays there
SN EB3A2329001478981
Update ARM v2062.03
DSP v2056.13
Could you send me a firmware up datemine wont charge after using it until it shut off.Display says 100%
Updates ARMv2062.03
DSP v2056.13
Can I please get the updated firmware to correct this issue
There no error codes i tried charging with dc side and it worked 1 time and back not charging
