E3BA AC Stanby powe
Hello, I have tow Bluetti eb3a.
I have charged them with AC over night. in the next morning (after 8h) they ware Hot even tough charging had finished hours ago.
They ware apparently off, i turned on the display and it showed 000W in 100% cahre 000W out.
Exactly waht you would expect…
BUT they consumed About 54W input power event tough they append to be off and showed 0W input power.
i confirmed this by plugin one eb3a AC input in the other eb3a AC output
As you can see the lower station Ouputs > 50W
The upper station gets Hot but showed 0W input
@lambda The inverter of the EB3A being charged is started and has reached 100% charge, which is not actually charged. The input displayed on the EB3A screen refers to the charging power , therefore displayed as 0 W. The output of the other EB3A shows the apparent power (in this case, because the active power is 0 W, it is equivalent to the displayed reactive power), although there is display power, but it does not actually consume.
What dose this mean?
“The inverter of the EB3A being charged is started and has reached 100% charge, which is not actually charged.”
Pleases try to say it differently because i can’t understand.
“although there is display power, but it does not actually consume.”
I think we have a misunderstanding.
The EB3A is actually consuming real power. (its getting hot) its not only reactive power.
Its real power and heat is produced. the heat is coming from real power.
@lambda Both EB3As have reached 100% power, so they are not charged actually. Both EB3A inverters are started, and they consume their own power.
But why? the are apparently off. Not charging. not outputting.
And still They get Hot and the fan turns on regularly and they draw significant power.
They are consuming >8-9W Real power constantly. why?
The claim is 2-3W
Same problem here:
Apparent Power is VA not W!?
It displays Watts.
Apparent power would not cause heating. But my units gets so Hot and the Fan keeps starting regularly.
