Charge AC200MAX with a solar panel
Understood Scott . Perfectly well.
Here in spain the distribution goes with
or with decathlon.
I am deciding and waiting for the best price.
Another consideration is the trolley to transport the batteries kit.
An one single panel for the ac200max when using in portable mode.
In this process the victron equipment will be innecessary according to yours instructions.
Which additional module are you getting?
Why do you still need to use breakers? Do you cut the Solar power off when you are reaching 100% charge?
For a small installation you don’t really need one, however, I still prefer using a breaker, even if it’s just to turn solar off and on rather than unplug the cables.
Not as big of a deal on the AC200MAX, but for example on the AC200L, you can’t turn the unit off if any solar is coming in, so the breaker switch is nice to have.
