especially when they are providing information that are correct .
None of them talk about PV parallel mode. And you too keep talking about 15A per channel when you also state that the two chargers can be run in parallel doubling the current capacity. So the limit is in fact 30A and not 15A.
On your case, since you already have 2 strings, it’s probably a better option for you to keep the 2 controllers separated, each with 1 string, so they can track more efficiently the different voltage and current of the 2 strings since they will have different irradiation during the day. On this case, as an example, shadowing on 1 string will not affect the performance of the other string which will continue to produce.
I don’t see the advantage of that. All 9 panels are next to each other and look into the same direction. And there are no shadows.
At this point, I wish it will be already clear that if you would like to add a 3rd string you can just parallel it to another string to increase the current into one of the 2 charge controllers and therefore to increase the production during low irradiation times such as in the morning or evening or during a cloudy day.
That would mean cutting off some of the production while still below 3000W. If I did it like that and 3 panels were producing 1000W then 6 panels on one charger wouldn’t produce 2000W but 1500W. With PV parallel mode enabled I would be getting 500W more out of it.
As a last note, you should make sure the 2 strings you are parallelizing have the same VoC. If your typical 3-panel string has a VoC of 125.4 volt, the 3 panel string you will parallelize to this string should have the same VoC to avoid the panel back-feed diodes to dissipate the bias, but this is another story for another thread.
I’ve got 9 panels of same make and model. So that won’t be an issue.
But it’s still 3 strings with 3 panels each.
And none of that answers my second question:
Does the “PV parallel” mode of the AC500 connect DC1 and DC2 internally? Or do I have to connect them externally with a y-cable?
Or asked another way: I’ve got a single panel with Voc 120V and Isc 20A. Can I just connect that to the MC4 connectors of DC1 and DC2 will get half of the current? Or do I need to split up the MC4 connectors of the single panel with a y-cable so that I can connect it to both externally?
