AC180P turns off randomly
Hi, I no longer disconnect at 100%, but disconnections at 99% appeared. Could you please send me an 04 update?
AC180P2349000709407
ARM - 2089,02
DSP - 2088,03
BMS - 1039,01
I have the same problem: it randomly turns off when the grid disconnects in UPS mode. Please push the new firmware. SN:
AC180P2344000331892
ARM V2125.01
DSP V2126.02
BMS v1048.03
The above request will be processed in 24 hours.
Hello, same issue here. Looking forward to receiving an update!
SN: AC180P2335001641541
ARM: v2089.02
DSP: v2088.02
BMS: 1039.01
Hi, same problem, AC180P turns off in UPS mode (ECO off).
SN - AC180P2349000755939
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Could you please send me update?
AC180P2344000318647
ARM - 2125,01
DSP - 2126,02
BMS - 1048,03
Today I also had a similar problem, the station shut down during a power outage, I turned off the ECO mode, but I would still like to receive an update.
AC180P2341000800566
ARM v2089,02
DPS v2088,02
BMS v1039,01
@BLUETTI_CARE
Hello again,
I would like to request a firmware with fix for my another ac180p device, please and thank you
SN: AC180P2335000869887
ARM v2089.02
DSP v2088.02
BMS v1039.01
I have a problem with UPS mode in Bluetti AC180P
s/n 2332001379568
bms v1039,01
arm v2089,02
dsp v2088,02
@BLUETTI_CARE
have the same problem as described above. When at 100% battery and losing power from grid the station just shut downs by itself. Could you please also push this firmware to me?
AC180P2348001108115
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Hey, I have the same problem as described above. When at 100% battery and losing power from grid the station just shut downs by itself. Could you please also push this firmware to me?
AC180P2335000497275
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Exactly the same problem here.
Shutdown occurs only at 100% SoC but sometimes it is seemingly at random, without grid power loss.
Setting sleep timer to never does not resolve the problem. ECO mode is off. No alert/error messages are provided through the app.
Written on the box:
POWIT-AC180P-EU-GY-BL-01
RVPWIT-230825-0001-69
UN3480
4G/Y23/S/23
CN/C520203
PI: 036
P/N: 17.0301.1252-01A1
In the application
AC180P2335000551488
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello!
I just received the device. Heard that the issue is very common, so kindly asking to push the firmware with the fix to my charger as well.
SN: AC180P2335000886619
ARM v2089.02
DSP v2088.02
BMS v1039.01
Good day. I have the same problem. Shutting down the station immediately after cutting off the mains power supply at 100% battery charge. Eco mode is off.
AC180P2349001448270
SN 2349001448270
AMR v 2089.02
DSP v2088.02
BMS v1039.01
The above requests will be processed in 24 hours. And also welcome the feedback for the firmware. Thank you.
Hi @BLUETTI_CARE,
I’ve bought the second AC180P and as long as the first one works perfectly on 2088.04 firmware, I would like to get the new version and on a new one. Thank you!
AC180P2349000567444
ARM 2089.02
DSP 2088.02
BMS 1039.01
Same problem with FANS on 04 firmware.
Yes, @moni , this problem was on out-of-the-box 02 firmware and migrated to 04 firmware.
Please, @BLUETTI_CARE , address the fan issue with the fan speed/cooling logic during small loads under 15 watts.
Got DSP update to V2126.03: works fine, no shutdowns anymore :+1:
Hi! I am going to use my AC180P power station as UPS and have outdated firmware version on it.
Please, could you send firmware update to me?
S/N AC180P2341000643972
ARM v2089.02
DSP v2088.02
BMS v1039.01
