Hello @BLUETTI_CARE
I have turn off issue too. Please, share the updated firmware to my device
Model: AC180P
AC180P2341000142876
ARM: v2089.02
DSP: v2088.02
BSM: v1039.01
Thank you!
Hi! Bad news - just when you removed the reminder (like 12 hours ago), the problem returned (or it was there the whole time). DC off, AC on, and loaded with small devices <15w - fans go from off to bananas after ~30 minutes, reproduced it multiple times through the night.
Didn’t you remove the new 2088.99 firmware from my device along with the reminder by any chance?
Maybe it’s just a coincidence and I had a really strong sleep a couple of nights prior and noticed it only today ![]()
Thanks! Receive an update! All working correct now ![]()
Hello @BLUETTI_CARE
I have the same issue. Please, share the updated firmware to my device
AC180P2349002122399
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi, same problem, AC180P turns off in UPS mode (ECO off).
SN - AC180P2352000977378
ARM - 2089.03
DSP - 2088.02
BMS - 1039.01
Please send me new Firmware DSP 2088.04
Thank you!
Привіт,@BLUETTI_CARE! У мене та ж проблема, вимикається режим безперебійного живлення. Я писав запит на нову прошивку в суботу, але, на жаль, мені її не надіслали. Надішліть мені, будь ласка, нову версію
Серійний номер: 180P2344000604421
ARM v2089,02
DSP v 2088,02
BMS v 1039,01
Велике спасибі!
Hi, I have same problem too, AC180P turns off in UPS mode (ECO off).
SN - 2332001031195
ARM - 2089.02
DSP - 2088.02
BMS - 1039.01
Thank you!
Hello
I have the same problem. Please, send me a new firmware to fix it.
Thank you in advance!
AC180P2341000399956
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2341000506873
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello, I have the same problem. Could you please send me an update?
AC180P2335001399456
ARM 2089.02
DSP 2088.02
BMS 1039.01
AC180P2344000546739
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Доброго дня!@BLUETTI_CARE В мене проблема з заряджанням станції від генератора, при підключені клацає і вимикається, чи є якесь вирішення цієї проблеми?
AC180P2335001449425
SN2335001449425
BMS v1039.01
ARM v2089.02
DSP v2088.02
Good afternoon. send updates to my Charging Station
AC60P2341000091967
ARM v2090,02- >v2090,03
DSP v2075,04
new firmware DSP -2088.04 please
Hi. When at 100% battery the station shut downs by itself after some time (ECO - off). Send my please updates to my station
AC180P2349001393870
SN 2349001393870
BMS v1039.01
ARM v2089.02
DSP v2088.02
@BLUETTI_CARE Please help to update the firmware.
Hello @BLUETTI_CARE
AC180P2332001418468
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hello @BLUETTI_CARE,
Have the same problem, when my AC180P gets charged up to 100% and Grid turns off
then my AC180P turns off completely.
Please provide me with a firmware update,
thank you!
AC180P2342000494514
ARM v2089.02
DSP v2088.02
BMS v1039.01
I have the same problem. When at 100% battery the station shut downs by itself after some time (ECO is off).
@BLUETTI_CARE Could you please also push this firmware to me?
AC180P2349000124177
ARM 2089.02
DSP 2088.02
BMS 1039.01
AC180P2352000455347
ARM v2089,03
DSP v2088,02
BMS v1039,01
Hello @BLUETTI_CARE!
I have the same problem: my Bluetti AC180P turns off when the mains power goes out and there is increasing fan speed at normal temperature during charging in silent mode.
Please send me the updated firmware.
S/N AC180P 2342000823906
ARM-v2089.02
DSP-v2088.02
BMS-v1039.01
Hello.
When the power is turned off, the station also turns off.
AC180P2349000113882
ARM v2089.02
DSP v2088.02
BMS v1039.01
