AC180P turns off randomly
Hello! Can I ask you to push new 04 firmware to me? Thank you!
AC180P2335001331828
ARM: 2089,02
DSP: 2088,02
BMS: 1039,01
Hello @BLUETTI_CARE Please send a firmware update to my device.
Model: AC180P
SN2332001163567
ARM v2089.02
DSP v2088.02
BMS v1039.01
I have faced with the same problem
AC180P2344004340252
ARM v2089.02
DSP v2088.02
BMS v1039.01
Please push new firmware for my device as well, thank you!
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank your
ARM 2089,02
DSP v2088,02
BMS v1039,01
@BLUETTI_CARE
Hello @BLUETTI_CARE
Unfortunately, I have the same problem.
AC180P2335001549470
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Can you, please, send me the new firmware version?
Hello, I heve the problem
Error: E013
Grid Relay Failure
Please provide me the new firmware for my station to work in UPS mode
AC60P2341000091967
ARM v2090,02- >v2090,03
DSP v2075,04
Hello @BLUETTI_CARE
I have the same issue. When at fully charged battery grid turned off the station sometimes shut downs by itself.
Could you please also push this firmware to me?
AC180P2341000766985
ARM 2089.02
DSP 2088.02
BMS 1039.01
Hi @BLUETTI_CARE ,
Having the same issue with my new AC180P. It works like UPS for fridge (~130 watts) When it’s fully charged and works as passthrough from Grid, on power off it’s shots down.
Eco is disabled. Silent charging mode.
SN: AC180P2341000170432
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Please push firmware update to the device. Thanks
UPD July 09th,
It was mentioned here that global update will be available on July 08th. Still don’t see any.
Please provide estimates when the update will be available or push update directly for my device.
The ac180p turns off when operating in UPS mode, an update is needed. Thank you.
AC180P2342000274156
ARM version v2089.02
DSP version v2088.02
BMS version v1039.01
when can you solve this?
Hello. Same problem here. Can you please push new firmware version to me?
AC180P2344002036620
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hello @BLUETTI_CARE. Same problem here. Can you please push new firmware version to me?
AC180P2344000664925
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Hi @VSM , yes, it is. If you have upgraded the new DSP, please ignore the reminder, we will delete it later.
AC180P2344000909225
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
Greetings, @BLUETTI_CARE
I have a simillar problem with AC180P
Randomly shuts down when starting to charge or after disconnect from charging without any errors displayed
Pls help me too
SN: 2349001777338
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Hello, @BLUETTI_CARE
I just received my power station. I don’t see any available updates.
I haven’t tested the disconnection yet, but please update to the latest version to avoid possible problems.
AC180P2349000539202
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Hello, I have a bluetti AC180P2342000290475, ARM v 2089.02 DSP v 2088.02, BMS v 1039.01 When the station operates in UPS mode, then when the network power goes out, the bluetti turns off completely, but should continue to work. Please send me a new firmware to fix this problem. Thank you!
Hi! Send firmware for stable operation in ups mode.
AC180P2341000261773
ARM v2089.02
DSP v2088.02
BMS v1039.01
Hi! @BLUETTI_CARE It seems that I have the same issue as @VSM. After new update fans turning on the high (max) speed and never turn off or slow down when loading <100w
It was the same on the old firmware for me (2088.02) :wink: And I made it clear in several posts.
As for the newest “exclusive” one (2088.99) - everything seems fine so far. But I’ll keep testing for a few more days.
Hello. I have the same problem as described above. Could you please also push this firmware to me?
Thanks in advance
AC180P2335001774495
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
